azpete
Jan 14, 2016Explorer
i also replaced my rm1200 norcold cooling unit with an amish unit. i replaced both fans with some fans that i got at frys electronics. they moved more air. i replaced the thermostat for the fans.
i replaced the control circuit board with a dinosaur board. the norcold board had a very brown spot on where the 110 volt was supplied to the heating elements,
i would bet thats where all the fires originate. i have always ran mine on propane, so i dont know why there would be a section that was over heated from 110 volts.
the most important part i replaced, other than the cooling unit was the burner tube.
when i replaced the coil and ran the refrig, it still didnt cool to a very low temp. when i replaced the burner tube, it made an amazing difference. the man from pine refrigeration said he always replaces the burner when he does a cooling unit replacement.
i now have a refrig that works great even in las vegas during the summer. it was 115 degrees the 4 days we stayed there.
pine refrigeration is a great place to do business with
i also want to give doug credit for all those he has helped. its nice to have someone is willing to help.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
