Executive45
Jan 27, 2016Explorer III
Here's what I did to mine. Hope this helps..Dennis
I wired the four fans in parallel and used a piece of kite string with a small bolt attached to drop down from the roof to the fridge opening. I then used the string as a pull wire to get the wiring to the back of the fridge. I put a switch in so I could activate the fans when needed. I used 14ga automotive wire and connected it to the brown wire I believe. Please use a meter to verify it's 12VDC. You can hook the fans up to any 12VDC source......Dennis
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
