aruba5er
Jan 21, 2017Explorer
All I can see is smoke and fire. Maybe ambulance, fire trucks. Insurance agents. You name it. If the Plug, (male) is getting hot, you probably got a bad Outlet (female) Trying to splice #6's into a 30 amp plug sounds like fun (four # 6 wires in a space where 3 # 10's should go. Yes, if you are working with the male end of the cord you will need to put the red and black together. If working on the female end out the cord (Receptable or oulet) then black and red must be seperated or dead short. BOOM Based on your voltage swing, you could add as much as 7 amps because of low voltage which make plugs hotter.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
