wolfe10
Jan 21, 2017Explorer
Canadian Rainbirds wrote:
The plug on the 50 A cord is showing signs of extended heating--rubber pulled away slightly from the metal prongs on both hots and the neutral. The U ground is OK. The 50A cord is hot only for the foot or two nearest the plug.
The above in the very first post.
That is why the short term solution (in Mexico with few RV part available) is to splice the 30 amp male (adapter) to the good wire of the 50 amp shore power cord.
Yes, preference to do the splicing in a junction box, but could also "sleeve" the splice with shrink wrap as a second choice.
This is NOT rocket science. Many of us have made hundreds of electrical splices/connections and are still alive to tell about it.
Very likely the problem is the prong to wire connection(s)in the 50 amp male end.
And, when back in the states, can just install a new 50 amp male end.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
