Matt_Colie
Aug 30, 2014Explorer II
Wiz,
I was in a position of repairing things without parts for many years. No outside patch will hold on the PE tank at those pressures and temperatures. What will work is the smallest sheet metal screw you can find and just drive it into the hole. any thing larger that the smallest will have more force on it. The compression of the plastic around the screw is on your side. No sealant should be required.
Good Luck
Matt
Good Luck
Matt
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
