NRALIFR
May 10, 2021Explorer
I can’t tell from your post, so I’ll just ask:
Is the input wire to the DC-DC charger switched? In other words, is it energized all the time, or does it become energized when you start the vehicle, or flip a switch manually?
If it’s already switched, then you just connect the “starter wire” (D+ Ignition) to the same source as the +DC input terminal. Unless your wanting to have total control over when the DC-DC charger is actually charging, then you would run the D+ Ignition wire from the +DC source, then through a switch, then connect it to the +DC input terminal on the DC-DC charger.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
