RVweekends's avatar
RVweekends
Updated- end of thread,something in the black tank.
Any idea how to get the circled part of this picture out of our blank tank? It came off while we were using it. We can't see much down there because of a bend in the pipe. At least the tank is clean. Any ideas?
  • Leave it in. What harm can it do. If it comes out when you flush so what. I assume that if you had it you would not try to repair it.
  • Since I've done something similar I can tell you. If your dump valve is a straight shot take a long 2x2 with a small angle piece attached and fish for it. Of course you'll have to empty your tank first--just make sure you only open the dump valve part way and your rinse hose won't escape.
    OTOH, you could just let it escape into the dumjp tank and buy a new one for like $20.
  • agesilaus wrote:
    Pipeman wrote:
    mechanic's magnet maybe????? Taped on a longer, bendable rod
    If that braided hose is austenitic stainless steel (type 316) then it would be non-magnetic. Can't hurt to try tho. Maybe a tool grabber like this:
    Pick up tool
    Grabber tool,there is nothing magnetic on that part,just tried a magnet on mine.
    Pick up tool
  • Industrial grade magnet on a line? You need a way to jockey it around in there though....couldn't be too far out of sight.
  • Do you have access to the top of your black tank? We cut a hole in the top of ours and installed a boat Deck Plate just in case something like this ever happened. We also use it to more throughly clean the black tank from time to time.
  • mechanic's magnet maybe????? Taped on a longer, bendable rod
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
