Almot
May 03, 2013Explorer III
Crosscheck, it's not that "all electric fridges don't work unless you are hooked up". It's that 120V fridge won't work unless you have a lot of batteries and means to charge them, or you are hooked up.
Yours is 7.5 cu.ft 12V, and even though it's big for a 12V model, it's an equivalent of a small office fridge - not a residential fridge. With an added bonus of not using an inverter, its energy efficiency is boosted by another 10-15%. The net result is 50-70 AH in 24 hours compared to 90-110 AH of residential unit. This comes at a steep price, 4-5 times higher than a bigger volume residential unit from big box stores. For a longterm boondocking away from propane sources 12V fridge and solar is the way to go, yes. 7.5 cu.ft with 300W looks underpowered for cloudy locations like BC. Your batteries will stay undercharged, dropping to 50% or below and never reaching 100% (you might think it's 100, while it's not), without a generator. But it will work.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
