wa8yxm
Oct 10, 2019Explorer III
1: water pump
on the inlet side of the water pump is a strainer. Lay a towel on the floor below it and open the case. Drain the water out of it and run the pump for like a minute to clear the lines. Then blow again. (Do this after the 1st or second of like 10 blows to get all water out)
2 Toliet. Flush wile blowing to insure that line is clear
3:Re black/gray water.. If less than 5 gallons can you bucket carry to a toilet?
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
