schlep1967
Oct 10, 2019Nomad
Your on a ranch. Got any Hay or straw bales? Stack them up around the bottom of the RV all the way around to block out as much air as possible. Before you put the last one in Hang a trouble light from the frame near the tanks. Should keep it warm enough under there to keep the tanks from freezing. Empty and bypass the water heater, blow out the lines and/or add antifreeze to the system.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
