MFL
Oct 10, 2019Nomad II
allen8106 wrote:MFL wrote:
If you blow everything out, and run the pump dry, you should be okay inside a barn. Big difference between temp of 25, and 10. I am thinking inside the barn should stay considerably warmer than out door temp. An electric heater inside should protect pipes. If you are sure of the small amount in tanks, they should survive too, as long as you are in the barn.
This is just an opinion, don't call me if everything freezes solid. :)
Jerry
Not sure where you got the idea he was in a barn!!
"I will be running a small electric heater inside the unit which should help keep the temp inside above freezing, and the TT will be parked inside a barn out of the wind."
Reading comprehension starts by reading entire OP
Jerry
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
