Son_of_Norway's avatar
Jun 16, 2019
Use a solar controller as a DC to DC charger?
I have been thinking about installing a DC to DC charger to properly charge my coach batteries from my alternator while driving. I have a dual-output alternator that delivers a constant voltage of about 14.4 V to the coach batteries. The DC to DC chargers I see are pretty expensive. I had the idea, why not just install a properly-sized solar controller, maybe about 30 amps, for the job. Is there something that I don't understand about this or will a solar controller work? Thanks for your advice.
  • wopachop wrote:
    Fun topic i like learning here
    Let's hope the OP does too.
  • wopachop,
    The alternator and "brains" see the starter battery. When it is full (which happens quickly) very little charging happens.
  • Fun topic i like learning here. Isnt the limitations wire size and amp output? How many amps would you guys expect he could get to the house batteries assuming he had proper wire gauge?
    I think with a tow behind setup isnt it only around 2 amps back to the trailer plug? That is due to wire size correct, not the alternator output?
  • If you're going to spend money on a solar controller, why not put on a few panels? My moderate battery bank is full within a few hours of the sun coming up. Why make it complicated?
  • all solar controllers 'buck' the voltage that is reduce the input from somewhere above 15+ even 12v panels have an open circuit voltage 21+
    no solar controller i have read the specs on will increase voltage on the output side
    MPPT will take higher voltage and make more amps at battery charging voltage
    but that is still less voltage than what is on the input side
    you need DC to DC voltage BOOST, output volts higher than input volts
    that doesnt come cheap
  • An MPPT controller is a buck converter so output is lower in voltage than input.
    We had some threads about using controllers with other than solar panels as input such as a DC power supply, and it does work in some cases (not all) I forget the details. Idea was to take advantage of the controller's adjustable settings ISTR.
  • Not sure if the 14.4 is enough to properly operate a controller, never seen a minimum voltage spec.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
