Orcadrvr's avatar
Orcadrvr
Use of clamp on dc ammeter
Well, I'm kind of stumped.
I'm trying to measure a phantom draw on my daughter's car by using a clamp on Sears AC/DC ammeter at the car battery.
I can only get the readout of OL (Open limit?) on the 0-40 amps DC range, no matter what I do. On the 0-400 DC amps range, I can get it to read about zero when I press the "zero" button on the meter, but I think that's the wrong range to measure what I am trying to determine.
It is a sears model 82369, clamp type meter. It also has leads, which I have disconnected for this purpose.
Thanks for any assistance. I know there are a lot of electricity savvy guys on this forum.
  • Thanks for the help, guys. It seems to be working now.
    I tried it again, put the clamps around the negative wire from the battery ( it was easiest to reach), turned the meter to DC Amps 0-40, and it started giving out random numbers. I zeroed it, as suggested, and it started to read out the draw.
    I believe the culprit is the car radio, which we saw going on and off by itself while the car was parked the other night. This AM, we had a dead battery (almost new battery, by the way). I measured the amp draw with the radio fuse pulled, and it was very minimal. When I put the fuse back in, with the radio off, it was pulling about 1 1/2 amps, which I think would account for the dead battery. I think I need a new radio!
    Thanks very much. I knew you guys would come through!
  • If it works with detecting the lights - and turning off everything (but the phantom) results in a meter reading of 0 amps, then you can be certain it will detect a few amps current. At that stage, I stop using the clamp on and pull the battery cable - then use the meter leads on a 10A scale - with the leads connected between the battery and the removed cable.
    That will easily detect low current draws. Just be sure you don't inadvertently turn on something or try to start the vehicle, which will blow the meter due to current overload.
    (I don't recall if the Sears meter has direct current detection with the leads - but many meters do).
  • Phantom draw will be very low, probably <50mA range or lower. Then after the car sits "idle" for awhile (no activity through the computer for 10- 30 min) it will be even go lower than that. I'm not sure you will be able to see such small ranges on that meter.
    Be sure to zero the meter with the jaws closed, and not around a wire. Then try the lowest range 0-20A to see if it can detect that small current. Clamp on meters don't do well when there isn't much magnetic field built up around a conductor unless they have an external sample loop.
    Yes, try the experiment suggested by Drycamper11 to see if the meter will indicate a higher current. Headlights should be fine at the 0-20A scale.
  • Orcadrvr wrote:
    I put it around only one wire, but no change.
    With it on the positive or negative battery cable, turn on the headlights, parking lights and radio and see what you get there. If you are using it correctly, it should show a large draw. Once you know it's working, start turning things off.
  • Hit the zero button on 0 to 40 . It's got to be around a hot lead I believe maybe to small to measure.
  • Did you put the clamp around a single wire? Can't put it around multiple wires or cables.
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 01, 2025
