ryoung's avatar
ryoung
Using a battery maintainer
I'm going to store my Ram diesel truck for about 5 months and want to keep the batteries charged with a battery maintainer. Will I need to disconnect the batteries to do this?
ryoung
  • I have a collection of Battery Tenders. The 3 amp units do a great job on my CTD and single battery cars. I don't disconnect anything on the vehicles because the 3 amp units provide way more than the parasitic loads. Craig
  • MEXICOWANDERER wrote:
    Peek A Boo spurious loads are about the only thing that can upset the apple cart. That, and as mentioned above -- extended power outages in conjunction with tiny loads that should not be there, anyway.
    Not sure what you mean about tiny loads that should not be there. The maintainer that I had was the load that run the battery down.
    Some maintainers put a small load on the battery even when they do not have a power input.
  • Peek A Boo spurious loads are about the only thing that can upset the apple cart. That, and as mentioned above -- extended power outages in conjunction with tiny loads that should not be there, anyway.
  • Do not use a GFI outlet. I did this on a car for 6 months and some time during the 5 months the GFI tripped possibly due to a power surg.
    The maintainer dropped the battery voltage to about 3 volts which destroyed the battery..
  • I put mine on a timer for 8 to 10 hours a day.(coldest hours of the day) It doesn't need to be on 24/7. Done this for 13 years with my truck and no problems.
  • no this way the clock and the computer will be running which is not a bad thing
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 07, 2025
