2oldman
Mar 14, 2014Explorer II
mexicanfooddude wrote:It will work if you get a controller that will accept nomimal 36v input...assuming this IS a nominal 36v. Yes, a 20 amp model is fine.. for that ONE panel.
40.5 volts, and a rated current of 6.05 amps. : will this 40.5 volt panel work with a Morningstar PWN charge controller to properly charge the batteries? ... what amperage charge controller do I need? I was guessing the 20 amp.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
