BoonHauler
Mar 19, 2014Explorer
pianotuna wrote:
Hi BoonHauler,
The upper limit for a 12 volt bank and a 60 amp controller is 1250 watts. Above that wattage the choices for a controller get expensive and limited, unless two are used in parallel (expensive, again!).
Do you have a "short list" for controllers?BoonHauler wrote:
Don, I still have to run a load test on a 12 VDC ceiling fan and decide on what roof top A/C I'll be running with but somewhere between 1.25 and 1.5kw, most likely the later.
Don, I'm adding another 60 amp CC. I'm staying with Morningstar. As for the upper limit of a TS-MPPT-60 I see it as 800 watts.
