mexicanfooddude
Mar 14, 2014Explorer
Using a residential PV panel on RV
Hi everyone,
Newly registered to the forum here, I've been reading a lot of helpful information here over the past year while doing my conversion though. I haven't been able to find a straight answer to this, so thought I'd probe the minds of the members...
I've got a friend with an extra Sunpower 245 watt residential solar panel, specs shown here. It has a rated voltage of 40.5 volts, and a rated current of 6.05 amps. I'd like to integrate this onto my bus with a Morningstar PWN controller, but am unsure if it will work with a typical RV power system/charge controller. I currently have two 215 amp-hour 6V batteries wired in series, connected to a PD-4000 converter/charger. Our load is pretty light: LED lights, water pump, and very efficient 12V refrigerator. That's it.
I know the usual RV PV panels have an output voltage of ~ 17 volts. So, my question: will this 40.5 volt panel work with a Morningstar PWN charge controller to properly charge the batteries? If it will work, what amperage charge controller do I need? I was guessing the 20 amp.
Thanks for the help!
