wa8yxm
Jul 17, 2022Explorer III
I used one to good effect in Arizona.. Not so much in Michigan. (For reasons already discussed) In AZ I also had to use nose spray due to the dryness of the air.
Now... One thing that might help (I STRESS MIGHT) might also make thigns worse is "Misting" the condenser. You want to mist the "inlet" side of the condenser (On most A/C's that is the side you can't see.. Coleman it's the side you can see)
How to do that safely is not something I wish to get into but they make mister nozzles for swamp cooling a patio. Two issues however.> Minerals can build up on the condenser clogging it. and discoloring it. and the dang mister nozzles like to clog.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
