time2roll
Aug 14, 2019Nomad
opnspaces wrote:Yes any newer automatic will work fine.
My question is, can any newer, automatic battery charger be used for to keep the coach 12 volt running? Or does a person need to look for a cheaper (possibly something from Harbor Freight) charger?
Your choice to shop at HF but low price is not a necessity.
I recommend 5 amps minimum with 10+ being much better for a portable. Ignor the 'start' or 'boost' rating for general battery charging.
If you have a WFCO converter, do not replace with same when you get around to fixing it.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
