Kemahsabe
Aug 21, 2014Explorer
Kpackpackkelley wrote:
I wonder why they can't use ethanol gas in airplanes. When I found that out I got a little suspicious .
EVERYTHING used to make or operate an airplane has to go through FAA certification. It's a long, expensive process. Consequently, very few improvements or changes are made. Last I heard, small aircraft engines were still using carburetors and magneto ignition. (Maybe that's changed - it's been a long time.)
So, who's going to pay to certify an engine to use auto gas with 10% ethanol? There's no money in it, so nobody is going to do it. It's not that it is a bad idea, or won't work. It just hasn't been certified for use in aircraft engines.
You can get an Auto Gas STC (Supplemental Type Certificate) for 48 engine types and over 100 airframes. However, "the use of gasoline containing alcohol must be avoided because it can cause corrosion in the engine, damage the aircraft fuel system, decrease range, and increase the tendency toward vapor lock." It also cannot be used in commercial operations.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
