MEXICOWANDERER
Dec 22, 2014Explorer
Disconnect one battery's wire from solenoid. If both batteries keep marching in lockstep the solenoid will have been eliminate as a suspect. I assssssume you did check for the presence or no of voltage to one of the solenoid coil terminals?
Also, a charge solenoid power studs should have only TWO battery wires connected to it - not three or thirteen. If you have more than two wires connected to the vig studs, someone screwed up. One oe more wires is fitted to the wrong stus.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
