Tom_M1
Jul 08, 2022Explorer
klutchdust wrote:The Winegard Sensar IV (aka Batwing) is considered about the best RV TV antenna available. It has the broad elements that are needed for receiving VHF channels well. Second choice would probably be the King Jack. It does not have the broad elements so it works poorly for the VHF channels but is on par with the Sensar IV for UHF channels. About 25% of TV stations are now broadcasting on VHF so for full coverage the Sensar IV would be the better choice.
Was discussing with a few friends that my TT does not have reception on the TV. I no longer have a satellite carrier and don't know much about the antenna on my 2012 work and Play trailer. One person commented he purchased a smart Tv with roku and uses his phone as a hotspot. So, what amount of data would it use. What are the downsides of this. Antenna upgrade? thanks in advance.
A former forum member did an extensive test comparing the two antennas. Here's a link to his test: SCVJeff's test.
If you intend to go with the Sensar IV, make sure there is room for the antenna when it is stowed. I had to install mine so that it stowed to the side rather than to the rear. I have had this for many years and have had no problems.
Both antennas are directional and need to be aimed toward the TV transmitter. Antennas Direct is a good site to locate where the TV transmitters are.
I live in Minneapolis and all the network affiliates here stream their local news in real time. I suspect this is true for most TV markets.
For cellphone I use Visible. It is the only service I know of that has truly unlimited data including hotspot use. If you join a 'Party Pay' plan the monthly cost is $25/month total, no added fees. It has worked very well for me.
