SoundGuy
Jan 16, 2017Explorer
rjsurfer wrote:
Well I tried running the desulfate mode on one disconnected pair and I'm only reading 14.6 volts at the battery pair so that's not right.
And did you first read the instructions regarding this 16v Boost Mode?
CAUTION. USE THIS MODE WITH CARE.
THIS MODE USES A HIGH VOLTAGE AND MAY CAUSE SOME WATER LOSS IN WET (FLOODED) CELL BATTERIES. BE ADVISED, SOME BATTERIES AND ELECTRONICS MAY BE SENSITIVE TO HIGH CHARGING VOLTAGES. FOR OPTIMAL RESULTS, TAKE THE BATTERY THROUGH A FULL CHARGE CYCLE, BRINGING THE BATTERY TO FULL CHARGE, BEFORE USING THIS MODE. TO MINIMIZE RISKS TO ELECTRONICS, DISCONNECT THE BATTERY BEFORE USING THIS MODE.
The timing of your posts suggests perhaps not. :@
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
