pianotuna
Jun 11, 2013Nomad III
Hi,
It can be done, but it is not easy to do.
Start with a quality inverter such as the new Magnum hybrid series.
Add AGM (or if your pockets are incredibly deep LI) batteries.
Use 12 volt jars.
Add a second alternator
Add as much solar as will fit on the roof.
Most 13500 btu air conditioners come in about 1300 watts. For each hour you wish to run two hundred amp-hours of storage are needed. So running while "in camp" is not too easy.
Assuming there is room for 800 watts of solar (derated to 500 watts because it has to be flat install when trundling down the road). The alternator needs to pick up the other 700 watts. 700/12 =~ 60 amps. That should be easily met by an auxiliary alternator.
It is doable but not cheap.
BTW I DO run my water heater (1121 watts) from my alternator/solar/inverter/battery bank.
Use 12 volt jars.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
