coolmom42
Sep 07, 2014Explorer II
helperzack wrote:
If it were me, I would check for leaks by filling a spray bottle with heavy dish washing soap and water and spray EVERY line and connection to check for leaks. With the tank valve open but everything else turned off.
I recently replaced the rubber hose from my tank to my line with a flexible metal hose. I like metal better than rubber.
Or as suggested above, have a professional check it out. Don't want to find any leaks the hard way.
Good advice. I agree on the metal flex hose.
After checking for leaks, turn the stove burner to the "light" position and give it a couple of seconds, then light with a long lighter. The burners use the most gas so that will flush out the main line fast. Then light the smaller flames.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
