pianotuna
Jun 04, 2015Nomad III
Hi,
This would be true if the jars were 12 volts in parallel. However, they are 6 volt in series, so each cell will receive a theoretically equal charge. If we split hairs, then like as not one cell will lag behind, which is why, from time to time the bank should be equalized.
If you follow the op's link it is a 1.5 watt panel, not 1.5 amps.
Chandalen wrote:
To explain a little more... any charge applied to your 6v batteries will be halved per battery. That is assuming they are balanced in condition and cables.
So that 1.5a charger is at best a 0.75 charger.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
