Buffalobilly's avatar
Buffalobilly
Using TV as Backup Camera Monitor
My unit uses the TV as a Monitor. Well the TV has failed. I have been trying to find a TV with a input for video using a RCA jack with out any luck.
The output for the B\W camera is analog I assume. Uses RG59 cable form rear to front.
Any ideas on the easiest way to adapt the output of my camera to these new TVs.
Thanks Bill
  • here is picture of the install
    no image on the display because ignition KEY is off and the camera is NOT on
    just want you to see how and where it mounts, very easy to use, no tilting head back neck pain
  • I went to FRYS electronics and bought a 7" flip down video screen
    The type mounted in mini vans for kids to watch video
    I mounted it under the cabinet, left of center , inline with the left windshield post.
    Perfect position much easier to use, not so hard on the neck
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
