jungleexplorer
Aug 11, 2017Explorer
Thanks guys. I was kinda thinking along those lines, so you just confirmed my worries on all points. The inverter is still in the box, so I can return it. The only reason I was worried about the propane option was because I was told that it is illegal in most states, and also because on my last TT (Kodiak 19FL) running the fridge on propane while moving would cause the fridge to go into error mode and I had take the circuit board out several times and perform a manual reset on it. It said right in the manual for that fridge that it had to be perfectly level when in operation or it would do this. I am not sure about this fridge on this Jayco though. Maybe it is different.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
