DownTheAvenue
Aug 12, 2017Explorer
jungleexplorer wrote:
The only reason I was worried about the propane option was because I was told that it is illegal in most states, and also because on my last TT (Kodiak 19FL) running the fridge on propane while moving would cause the fridge to go into error mode and I had take the circuit board out several times and perform a manual reset on it.
Since you believe what you are told, I am telling you to run your refrigerator on propane while traveling. Now that is out of the way. Your previous RV probably had a wind issue that kept blowing out the flame and causing the refrigerator to go into a fault mode. Try it with your new RV, if an issue just install a little baffle. You are making something easy and simple into something very complicated.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
