MrWizard
Aug 12, 2017Moderator
if you have a tow package and 7 pin
the battery should already being kept charged
if your thinking of inverter in the TT
25 amps is 25 amps from the alternator, no matter where the inverter is located
if your TT battery is running down while driving
you need to find out why ?
then run the additional charge wires if needed
other people have done this, sometimes there is too much voltage drop
from alternator to TT, the batteries barely get a trickle charge
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
