Jayco-noslide
Oct 22, 2019Explorer
If you just use water from your tank is 1 thing but if you hook to a city water, the hose will freeze upper 20s or less. Also, the valves to drain the tanks will freeze up. If it just get a few degrees below freezing for an hour or 2 might work but colder and longer is a problem.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 12, 2026
