scbwr
Oct 22, 2019Explorer II
You can get temperature sensors that have a remote and you can monitor the temps in the area of your water tank. There is also the option of plugging in a personal electric heater (low wattage) that will give off enough heat in the compartment to prevent freezing. The electric heater can be plugged into a thermal coupler that will cut in at a specified temp. My Bay Star gets enough heat in the water bay that I've had no problems when the temps were in the teens if I used the propane furnace.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 12, 2026
