The_Falcon's avatar
The_Falcon
V10 fuel filter replacement
I have a 2003 Four Winds MH with a Ford V10. Is there an inline fuel filter that can safely be changed by a regular person? If so, where is it located? I had a fuel pump replaced a couple of years ago and it said on the bill that they replaced a fuel filter, but I wonder if it is the one in the fuel tank.
Thanks
Joe
  • j-d's avatar
    j-d
    Explorer II
    This Archived Thread will cover it. Includes Location, Tools Needed, and Why to Get the Right Filter (aka So You Can Change it Again Next Time...)
  • As Red described, it's just about under the driver's seat on the frame rail. Easy to replace with the tool.
    Good info here.
    Also good description by BillArf in the second link above.
  • Look on the left frame rail behind the cab. You need the tool to release the clips, it is only a few bucks. Ford has two different size filters so take a look to see what one you have. YouTube has some videos on how to change.
    Here is a couple of links.
    http://www.fordf150.net/howto/fuelfilter.php
    http://www.rv.net/forums/index.cfm/fuseaction/thread/tid/23652133.cfm
Having RV issues? Connect with others who have been in your shoes.24,273 PostsLatest Activity: Jun 24, 2025
