busyguy's avatar
busyguy
Vacuum pump
Posted this on IRV2 and didn't get many response's So thought I would try here.
I have a 2000 Harney and the vacuum pump that controls the Heater and A/C is making a lot of noise and seems to run all the time.
I have found the exact replacement for $213.00 on Amazon and also one that looks almost the same for$53.00.
My question is. Is the rattling noise normal and will it have to be an exact model to replace it? Plenty of room for R&R. Every thing works fine. Just don"t like the constant rattle.
Thanks
Busyguy
  • Thanks guys
    Will get out and check for a tank and also leaks as soon as it gets warmer. Had 2 inches of snow here and 24 degrees this AM in Madison ,Ga
    Busyguy
  • It's not the pumps fault, you have a leak someplace and the new pump will run constantly if you don't fix it.
  • Have you checked to see if it has a vaccum reservoir in the system? That could be bad causing the pump to run all the time.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
