mena661
Nov 28, 2013Explorer
VARIAC....MEX?
Hopefully MEX will chime in but anyone else is welcome, of course. Looking to buy a VARIAC. I have a Harbor Freight manual charger that I use for equalizing and sometimes the finishing charge. The pro...
pianotuna wrote:Thanks for doing the math PT, Golden had me sweating for a moment. So I'll need to turn off the load BEFORE turning the dial?? Hmmm. I was hoping I could adjust the VARIAC while the charger was on to keep the output steady or to slow the rise. Turning it on and off seems like a PITA although I guess I would know where to turn the dial to after messing with it.
Hi Fred,
It is good to know that the dial should not be moved when there is a load on.
The unit referenced is rated at 500 VA. Give the battery charger 0.7 for power factor. 500 X 0.7 = 350 watts. Plenty for the 10 amp setting and enough for 20 amps. (20 x 12 = 240 / 0.7 = 343 watts)
