mena661
Nov 28, 2013Explorer
VARIAC....MEX?
Hopefully MEX will chime in but anyone else is welcome, of course. Looking to buy a VARIAC. I have a Harbor Freight manual charger that I use for equalizing and sometimes the finishing charge. The pro...
MEXICOWANDERER wrote:
Let's take it from the bottom. Mena is starting at the bottom. Least electrolysis. Then he is going to incrementally increase current until his charger is reading correct equalization potential. From there only slight and occasional tweaking during the equalization process will be needed. Bit by bit.
I took all the into account when I recommended he adjust the variac under load. My 3-amp, 5-amp and 7-amp variacs (Hwang Ho origin) all use the same carbon contact.
No, it isn't an Ohmite ceramic rheostat. So total contact lifespan may equal a few hundred feet rather than several miles of travel.
Moving the carbon very fast across the winding will definitely cause premature erosion. But the carbon can be replaced when necessary. After I'm dead.
