mena661ExplorerNov 28, 2013VARIAC....MEX?Hopefully MEX will chime in but anyone else is welcome, of course. Looking to buy a VARIAC. I have a Harbor Freight manual charger that I use for equalizing and sometimes the finishing charge. The pro...Show More
MrWizardModeratorDec 02, 2013yes it is differentadjusting the variac/sliding the contact changes the voltage and hence the loadgenerator brushes are designed to be in contact with a moving surface they are on two 'slip' rings for the 'feild' current , not the output loadthe 'load' of a generator output is applied to the output windings , not directly to the feild brushesthey are different surfaces with a different 'wear' factor
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
Related ContentRe: telcom battery bankRe: US Battery "finishing" charge recommendationRe: Variac For Equalizatiion Of BatteriesRe: OPINION The New Model Of Harbor Freight Charger Is GarbageRe: Magnum Inverter/Charger Design Tradeoffs
