Tom_M1
Mar 22, 2014Explorer
One thing to keep in mind is the weight of the panel. My 125 watt panel weighs about 30 pounds
and is a bit of a chore getting it back on the side of my coach. I've been kicking around replacing it with a
flexible panel. Here's a link to one that I'm considering:
EVTV Motor Verks panel
It's 180 watts and weighs 6.6 pounds. I'd have to add a frame to mount it on but it still would be quite light weight.
Before considering a flexible panel, check out AM Solar's test:
AM Solar flexible panel test
The issues they have with the the panel they tested should not be a problem for a vertical mounted panel.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
