mlts22's avatar
mlts22
Explorer II
Mar 19, 2014
Vertical mounting of PV panels worth doing?
Last weekend, I saw one rig that had solar panels mounted on the sides of the vehicle while at a stoplight. They didn't appear to fold out (no hinge mechanism or supports, and solid brackets with no latches apparent.) The roof of the rig was full of panels as well.
How useful is mounting panels on the side of a rig? I know that it means that it gets 65-70% less power than a horizontally mounted panel. However, a lot of rigs have a lot more space on the sides than the roof, so even if the panel is stuck with the cosine of the sun's angle and on average only sees the sun 1/2 of the day (with the exception of facing south), but 30% of a 300 watt panel part of the day is still 90 watts that wouldn't be coming in without the panel.
The reason this is interesting to me is that one motorhome I'm considering doesn't have much space on top, especially factoring shadows from objects like the A/C, skylights, and vents. However, it has an entire back section that is flat and windowless and one side that is also windowless. Since the MH is 90 inches wide, the extra 2-3 inches from a panel and mount wouldn't put it over width regulations. I can fit at least two, possibly three panels mounted on the back, and 1-2 panels on the sides. If the panels get 270 or so watts apiece, this would bring in ~100-200 watts total. With panels going for 75 cents a watt, it is more expensive than a decent rooftop system, but it can be a way to still get decent power, especially here in Texas, and if one can face either the side or the back towards the south.
  • Tom_M wrote:
    JiminDenver wrote:
    There is the member that has two panels mounted not only vertical but tillable and portable too.
    That most likely would be me.
    I think this is a pretty smart way to go. I really like the window awning application! And, you don't have to get on the roof to clean the panels.
    The panels can be propped up at an angle or easily removed.
    If I'm parked in the sun I can leave them attached.
    If I'm in the shade I can lift them off and set them in the sun.
    Hey, I tilt :C (just figured out that 58 degrees is more vertical than horizontal, too).
  • There is the member that has two panels mounted not only vertical but tillable and portable too.
  • westend wrote:
    I think it was Mena that went on his roof and made shade patterns for all of his rooftop accessories. You could search for his thread about how he overcame rooftop obstacles. As CA Traveller, said, when you start getting the modules up off the roof surface, you'll gain a lot of module real estate.
    This thread here: Solar Panel Placement on Roof
  • Hi,
    I am considering replacing my awning with vertically mounted panels. I would include tilt.
    In winter time vertical installs can get a greater harvest because of light "bouncing" off the snow.
  • These panels using 2" used aluminum screen porch material could have been mounted higher.
  • 90" will fit three 24V modules with an overhang of 15" total. I wouldn't do it.
    Since there are so many mounting choices and module sizes available, it really doesn't make too much sense to mount them on the sides of an RV. Only those with definite lack of roof real estate and needing large amounts of power need apply. To me, the downside of mounting on the sides (besides the inefficiency) is the possible damage from road debris.
  • The vertical mounted panels might be best during the winter when the sun is low. And since you're from TX where you might actually have winter sun...
    Every square foot on your rigs roof top with the exception of high antennas is available for solar panels. Many only consider mounting them 2" off the roof - start thinking higher even right over the ACs.
    Personally I would never consider vertical panels. But some are successful with hinged vertical panels...
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
