mikemc53's avatar
mikemc53
Explorer II
Nov 21, 2020
Very Frustrated
OK, bear with me on a long post.
Packed and ready to head south with unit loaded and ready for family. Had been on auxiliary power this past week and all appliances/accessories were functional. Went to start the motorhome (2004 Holiday Ramble Vacationer on Ford F53 Chassis) and it wouldn't turn over. Hit battery boost and it started up and ran well. Let it run about an hour or so and then needed to shut it sown to bring slides in. After that, no start - even with battery boost. Tried a separate, off the unit, battery booster that I have and still nothing.
Battery Minder says battery is desulfinated so I pulled the battery and went to town to find another. Could not match one up but bought what looked to be similar battery - it did not fit. I did, though, get it kind of hooked up just to see and still, no start. Took it back and picked up my old battery just for a placeholder. Put it back in and the unit started right up and turned over extremely well. Ran it for half an hour - shut it off...and since then, no start.
It seems to try, just one time...very slowly and then nothing. Can't figure out why it started a couple of times, but mostly nothing. Really didn't want a starter issue and not sure if that is even the case. Thought maybe a bad cell in battery but why would it start once or twice and then nothing?
If it was a starter why, again, would it once or twice but not any of the other times?
Very unhappy wife and pups - and one frustrated little Irishman.
Thoughts?
  • You probably need a multimeter to check the battery voltage, or take it to Auto Zone and they will do it for you. Could be the battery or the starter.
  • Bad relay.
    Burn commutator on starter.
    Loose bolt on wire at starter or relay.
  • You've posted no information (age, size, terminal condition, resting voltage, specific gravity, etc.) concerning the condition all of the battery(s) you currently have.
    That said, (assuming the batteries are good since the vehicle will start, . . . . well sometimes) I would be looking at the ignition switch, starter solenoid, booster switch, battery terminal connections, battery cables, etc.
    Chum lee
Having RV issues? Connect with others who have been in your shoes.24,305 PostsLatest Activity: Aug 27, 2025
