Smitty77
Dec 25, 2019Explorer
We have both the little and big Mr Heaters. Depending upon travel mode, we carry the small one with us most of he time. If going somewhere where we expect extreme colds, we'll swap out the little one for the big unit.
We do not use it for 7/24 heating. We use it for getting the coach up to temperature fast in the AM. I'll usually get up about an our ahead of the DW, and run the unit (And I do run it on our kitchen table:)!). On the big unit, I'll put on high, and turn on the auxiliary fan, until the temps inside reach mid 60's. Then step it back to low, which is he same BTU as the little unit on low too. It's on maybe an 1 1/2 - 2 hours total. When we swapped out our real danger, the Norcold 1200, I had the Propane Line stubbed out into the toe board below the Samsung RF18, with a quick disconnect and 1/4 on/off valve. So I can use a hose to the Mr Heater, with the appropriate filter inline.
All of this is while boon docking camping.
I'm anal about our safety in the coach, and have three different CO detectors. I have two windows opened the appropriate amount, and also the kitchen roof, closely above the table with the Mr Heater on it, is open 3-4" too. We do have multiple static dehumidifiers. THE UNIT IS NEVER LEFT UN-ATTENDED.
I feel it's just another part of our RV'ing arsenal, and like an device - if not maintained properly, and used properly - can be dangerous. But I feel ours is safe to use, obviously.
When not boon docking. We use Electric Floor Tile Heat and HydroHot on Electric element only, as well as a portable 1500W electric heater, for most of our coach heating. (In our rig, I need the HydroHot on aways, on real cold temps, to keep the water bay heated.)
I do feel this is one of those situations where all of us much make our own decisions.
Travel safe, have fun,
Smitty
Smitty
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
