Muddydogs's avatar
Muddydogs
VIAIR P88
After my cheap Costco compressor took a dump I surfed around the net for a new one. Due to the recommendations on this forum I purchased the Viair P88 off Amazon for $70.00. I just got done doing a little test of the unit and here is what I found for anyone interested.
I deflated a 245 75R 17 tire on a Dodge Ram by removing the valve stem and letting it go flat. I must say that the TPMS system sure restricts the air flow, I think it took longer to make the tire flat then it did to make it round again. Here are some recorded times for certain PSI's.
20 psi in 4 minutes
40 psi in 7 minutes
60 psi in 12 minutes
70 psi in 14 minutes
80 psi in 17 minutes.
The unit is way quieter than I expected it would be which is a little plus. The air hose was getting quite hot by the time I hit 80 psi but this is to be expected. One most defiantly doesn’t want to touch the cylinder head during or for a while after the compressor is run as it gets very hot. I found the attached pressure gauge to be within a pound or two of the truck read out, I checked this a couple times during the fill.
All in all I think this unit is a tough little guy which should store well in a truck or RV and handle getting bounced around until needed. Only time will tell how the pump holds up but most of the internet reviews are favorable.
  • I carry a 70P viair for my air bags on my camper and it is good for my truck tires too, $53. at KMS Tools, very good pump, 30 min.duty cycle @30 lbs, 100 lb pump.
  • I'm happy with mine. With trucks, trailers, motorcycles and bicycles, plus Momma's car, it gets a bit of use. I understand it has a 45% duty cycle, 4.5 minutes on, 5.5 minutes off, so running it for shorter periods might help with the heat situation. I rarely need to air-up more than a couple tires, so I don't mind the resting period in between. For the features and perceived quality, I think it's a great deal.
  • Yup! Glad you got one, too. I can't believe I went so long before getting a good compressor like this!
