- RamblinReflectExplorer II
I installed one on my unit. I love it.
- way2rollNavigator III
3 year old post and OP hasn't been on here since. Responding to old posts messes up the sort order of the recent topics.
🙄Here’s an idea. If the post is open it’s an invitation to be interacted with. If the sort order matters so much then the post should be closed. Otherwise what does it matter? Seriously?
- pianotunaNomad III
TechWriter wrote:
Does the Outback allow direct connection to the main electrical panel?
I don't know but the radian series allows dual AC inputs. That would suit me to a T. It is a hybrid as well. - TechWriterExplorer
3 tons wrote:
TechWriter wrote:
Anyone install the MultiPlus II?
As to the multi-plus I’m signing up with PT :) (assuming my ProSine 2.0 ever goes south??), but would opt for the 3000…You might also check at Youtube.
Yep. That's the bad boy I'm talking about.
Discovered the MultiPlus II from one of the videos on the All About RVs YouTube Site. Two months later he followed up with an install video.
I also like Chad Heiser's stuff. He confirmed that the MultiPlus II can be wired directly to a 50A electrical panel.pianotuna wrote:
Nope, but it is on my shortlist should I have a failure of the inverter/charger. The other one I'd consider is Outback.
Does the Outback allow direct connection to the main electrical panel? - 3_tonsExplorer III
3 tons - pianotunaNomad IIINope, but it is on my shortlist should I have a failure of the inverter/charger. The other one I'd consider is Outback.
Having RV issues? Connect with others who have been in your shoes.24,301 PostsLatest Activity: Aug 15, 2025
