Mako_Kupo's avatar
Mako_Kupo
Victron/lifeblue system 99% functional except
Hey everyone, been a while! I have my solar system installed, it is all Victron (5000w 12v quattro inverter)equipment with LiFeBlue(3x 200ah lithium)batteries. That means I am using the lynx bus bar and shunt to connect everything to the batteries safely. Most of the system works, I can put power in the batteries and use that power on 110v, can’t test out the 12 V yet but that shouldn’t be a problem. All of the information on the system is viewed through the color control screen made by Victron, and everything appears to be working properly .
However, I have gone through two lynx shunts. this is a fuse block that goes between the two busbars, it holds an 800 amp CNN fuse. The fuse has not blown, but both times I installed a new shunt it worked for a split second and then sparked, never to show a sign of life again . The shunt limits current to the batteries, and also prevents overcharge and over discharge. Its a ‘smart’ bus bar, and the spark appeared to happen on the small computer board next to the fuse in the shunt.
Even with the shunt not working, I can still use the system normally but i wont until its 100%. I can put up pictures when I get home in about an hour or two, but any ideas or thoughts will be helpful. Thank you all!
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
