Old-Biscuit
Sep 03, 2016Explorer III
MrWizard wrote:
It will notify you of an open neutral at the pedestal
Don't think it can tell you have an open/loose neutral in RV breaker box or transfer switch
Correct.......
EMS only monitors incoming power source.
What happens AFTER the EMS is NOT monitored.
OPEN NEUTRAL issue is/was in you AC Dist Panel (not at CG power pedestal)
Need to turn off AC power and then TIGHTEN ALL lugs.....L1, L2, Neutral and Ground Busses PLUS each individual AC Breaker Load side lugs
