cestlaviethree's avatar
Sep 03, 2016
Video: RV electrical fire...
Hey All,
Was hoping to hear from other owners on reasons for possible electrical fire.
Trailer: 2015 Outback Toy Hauler
Here is the story. Around midnight on Monday we woke up to the sound of what sounded like a breaker fuse trying to trip over and over again. Then there was a weird surging sound in the AC unit. I turned the AC off and opened the distribution panel. Were I could smell smoke immediately. I flipped on the lights and could see smoke coming from the panel. I began dropping all the power to the trailer, and we stayed that way till a service tech showed up in the morning.
The service tech opened the panel and we couldn't see any noticeable burn marks or melted wires...nothing. WEIRD!
However, our entire electrical system was possessed. The amperage draws were chaotic, the ACs were shifting loads between them both.
Then BOOM!
A capacitor on the converter blows creating a huge electrical arc. That's when the tech calls it and says he wants to work on it back at his shop.
We take the RV to his shop. He replaces the converter and...NOTHING. Everything works great. The amperage draws our normal, the ACs are running perfectly, there is no more issues in the electrical system.
QUESTIONS:
Could a bad converter have been the cause?
Videos:
Electrical Arc:
https://youtu.be/_ofvt8_cLvY
Video Story 1:
https://www.youtube.com/watch?v=NwMNr3KSIpY
Video Story 2:
Video Story 3:
https://www.youtube.com/watch?v=vUTVgELsQGY
-CLV3
  • Hard to tell unless you measured voltage.
    Yes if replacing the converter fixes the issue I believe that is all there was.
    What does voltage measure today on the main breakers in the RV? Does it change much as you turn on each air conditioner, water heater or microwave? Try a hairdryer on high in each outlet for additional testing.
  • Thanks Gent,
    -Yes, the EMS was plugged in for the duration of this episode.
    -I've started tightening, but nothing is loose yet.
    -On the main breakers today. I am pulling a healthy ~14amps on our AC vs the ~29amps as it was before. So it all seems to be in the proper range.
    Question: Does the AC require a 12VDC reference to start, similar to the refrigerator?
    Thanks again all.
    Yes or no, look up your model number.
    Generally yes, especially for the thermostat.
  • Hi,
    Rule of thumb -- it it has a thermostat on the wall it needs 12 volt for the control boards.
    Thanks again all.
  • -On the main breakers today. I am pulling a healthy ~14amps on our AC vs the ~29amps as it was before. So it all seems to be in the proper range.
    It may seem trivial to you but I'll ask once more, how is the amperage being measured? If you have a measuring system that isn't accurate, the information you get from it is worse than no information at all. 29 amps of draw would be very high for two A/C units running. 14 amps is on the low side for two units.
    Do you have other 120V devices besides the A/C units and the converter drawing power? Refrigerator or water heater on electric?
    Edit: OK, I found that the PD EMS displays amperage and I'm assuming that is what's referenced with the electrical draw. I believe this is probably fairly accurate. The large draw seen when the converter failed may have been the failing converter and now that it is replaced, hope all goes well.
    Sorry, thought you were asking the exact amount. We were using a Milwaukee clamp meter. The EMS cycles through its display so it was frustrating to take a reading every 20 seconds. So I never use the EMS for readings only as a comparison or reference point. I had the water heater and the refrigerator on the whole time. I turned the microwave on when I was troubleshooting.
    Thanks.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
