tragusa3's avatar
tragusa3
Video: Yamaha 2400 running a 15.5 BTU
In researching which generator to buy, I would have been helped by a video like this one, so I hope it helps someone else looking to buy.
Yamaha running 15.5 btu
So far, the Yamaha has done everything I hoped it would. It will run the entire trailer including microwave. But the main reason for going with a little extra capacity was running my 15.5 BTU A/C. I would be happy with my decision even if it hadn't, but it's a nice plus that it does!
For this video, I shut off all other circuits. I got the fan spinning on high first and then switched the compressor on. The gen bogged down for half a second, went up to a much higher rpm and then the compressor kicked over. Once running, the gen went back to about a half load and I ran it like that for 10 minutes.
My unit is a 2013, so I'm not sure if that means it already has a hard start capacitor? I'm hoping it doesn't, and I plan to add one. With that, I should have no concern about it working.
I'm at 1100 ft. elevation and the outside temp was about 63d.
