tragusa3's avatar
tragusa3
Video: Yamaha 2400 running a 15.5 BTU
In researching which generator to buy, I would have been helped by a video like this one, so I hope it helps someone else looking to buy.
Yamaha running 15.5 btu
So far, the Yamaha has done everything I hoped it would. It will run the entire trailer including microwave. But the main reason for going with a little extra capacity was running my 15.5 BTU A/C. I would be happy with my decision even if it hadn't, but it's a nice plus that it does!
For this video, I shut off all other circuits. I got the fan spinning on high first and then switched the compressor on. The gen bogged down for half a second, went up to a much higher rpm and then the compressor kicked over. Once running, the gen went back to about a half load and I ran it like that for 10 minutes.
My unit is a 2013, so I'm not sure if that means it already has a hard start capacitor? I'm hoping it doesn't, and I plan to add one. With that, I should have no concern about it working.
I'm at 1100 ft. elevation and the outside temp was about 63d.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
