- KatdaddyExplorer III have been using a fence post to hold my hoses for over 5 years now. I mounted the post on top of my camper's bumper. I bought allthread of the proper length and after measuring where the bends needed to be, heated the thread and bent it into a u shape. I drilled a piece of flat bar to accept the allthread under the bumper and bolted it into place. I drilled holes into each end and inserted a bolt. It holds the hoses in place, but allows plenty of air circulation. I did not drill any holes for drainage and have never had any problems.
- ependydadExplorer
westend wrote:
This is also what I did. I just don't have pictures. - Carb_CleanerExplorerThere are some ideas for mounting and closing HERE.
- wa8yxmExplorer IIIMine is tarp strapped (will soon double strap it) to the frame rails under my Damon Intruder.
I modified the "open" end of the post (the "Closed" end I simply screwed the cap on with screws)
I then attached the cover with a hinge on the top... (Had to use a shim or two under the pipe end of the common butt hinge) The end is modified so there is a "Tab" on the bottom, this tab extends through a "Slot" on the end cap (i may re-do it so it's just under the end cap by cutting the end cap)
A barrel latch drops through a hole in the tab
To keep it open when inserting/removing hose
I open the compartment door above it and let it close on the opened cap. this holds the cap, and then I need to get into that compartment anyway. - westendExplorerHose holder with gutter drawer:
- DarthMuffinExplorerHow are people keeping the cap on the fence post?
- HillyhikerExplorerWhere did you mount the post and what did you mount it to? Trying to figure out where to mount one on a B van. Photo examples would be very welcome if you have them. :-)
- cpaulsenExplorer IIGot my post cover @ HD about 5 years ago.....mounted at an angle sloping to the cap. Drilled 1" holes with a step drill. Never a problem with the burrs and I just slide the sewer hose with the connecters right into the post....put the fence post cap on and an done.
- Roundtwo-40ExplorerI used the U shaped gutter not the K shape.
- ependydadExplorer
tvman44 wrote:
Do what I did, get a length of PVC gutter material and slip into the fence post to use as a sliding tray. Solves that problem and makes access to hoses even easier, I keep 2 10' hoses in mine. :)PenMan wrote:
I also use a plastic gutter inside the 5x5 fence post to slide the hose in.
Use the plastic gutter as a drawer. No worries about burrs and makes it easy to get things in/out.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
