Horizon170's avatar
Horizon170
Voltage divider SOLVED
Would this work? I have a 1 mil CP, 6 volt spotlight bulb. Will a simple voltage divider using a couple of 100 ohm resisters work from my 12 volt lighter recept. in the dash?
Here is a better diagram.
Clicky
  • smkettner wrote:
    You may as well put two of those bulbs in series.
    Otherwise the resistor will be rather large to have the wattage rating you need.
    I only have the one bulb for a spotlight.
    See the new Clicky I added.
  • You may as well put two of those bulbs in series.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 19, 2026
